Hi all
Hope this is in the correct section.
I need some help understanding some of the options in my chosen software for ripping FLAC files from CD's
The software I use is Easy CD Audio Converter and as can be seen in the picture below it has a number of options, I did a few tests rippling the same track using some of the different options, but given that its a lossless format I am struggling to understand why there are so many settings and why the files are so different.
Attachment 27359
First files were ripped with all three settings at auto with just the compression setting adjusted and I got the following results
Q0 38mb 960kbps
Q5 35.5mb 884kbps
Q8 35mb 874mb
Uncompressed 56mb 1515kbps
Next test taking all the auto settings off with the first 2 changed to 24bit and Stereo with the third option only changed I get the following
48000 Hz 92.5mb 2309kbps
96000 Hz 185mb 4618kbps
384000 Hz 740mb 18481kbps
so the silly question is, if its a lossless format why so many settings and why so much difference between each file
Does it realy matter what setting used as far as the quality of the playback is concerned and what setting should I be using with this software.
I have listened to all seven files and to be honest I cant hear any difference between them, but that might just be down to my heavy industry damaged hearing, or is it?.
Thanks for any help with this.
Paul
