Originally Posted by
AJSki2fly
Hi Adrian
Not sure how Sony originally set up your model of Sony from CD/Laser sled point of view, but my experience with a Meridian 508 player may help to explain your issues.
The Meridian 506 and 508 both use a particular and very good Philips CD mechanism, this when built new was greased with a grease designed for plastics, the laser drive mechanism and worm wheel both being plastic. It is crucial that this mechanism moves freely so the laser can position and track accurately, if not the CD player will do all sorts of things and eventually not play at all and complain of no CD in the unit. All Meridian CD players eventually fail due to the same issue, the grease that Philips used goes hard over the years, and it can be so bad that the mechanism can get damaged, but not always. So the solution is very carefully clean it removing all old grease and then apply plastic grease that does not go hard, if this does not work then it is a new sled and laser I am afraid.
So it maybe that your CD mechanism is suffering from the same problem if Sony were guilty of using the same type of grease when it was made. I would carefully get to the sled determine if you can easily remove it from the unit so you can clean and re-grease, or if it has to be done in situ. I would check online to see if you can find any others who have had similar issues with this unit first, there is usually something out then, have you searched on Youtube for Sony CD player issues?
I hope that helps a bit.
Adrian
