Aluminium/ steel platter mats
Hi there,
I am looking at platter mats and record weights for non suspended TT, like Garrard 301, TD124, L75.
Platter mats
I hear the aluminium/steel/copper can give satisfying results. Those metals doesn't overdampen the TT, like rubber, cork, or leather can do. I say CAN do, because I have good results with my Herbie's Way Excellent II mat polymer mat on my Lenco L75. But I want to try a some kind of metal mat.
Anyone experience with the Puresound Tenuto Gunmetal mat, the Custom Design Inert, or the SPEC+ AP-UD1?
Custom Design offers two versions:
Aluminium for suspended turntables, and stainless steel for non suspended. I guess the steel is not a good idea if you use magnetic cartridges.
Record Weights
I can devise the record weights on the market in two groups, the heavy ones and the not so heavy ones. I have a feeling that the massive ones are not a good idea on my vintage TT, but I don't know why. Anyone any explanation? Does the weight put too much stress on the TT motor?
Do I need a 800 gram or a 450 gram weight on my vintage TT? Many thanks for your experiences.
Personally I’ve never liked the idea of metallic platter mats because of the likelihood of reflecting stylus vibrations back to the cartridge when the accepted wisdom is to channel it away from the cartridge and arm. A mat with a similar composition to vinyl being a good conduit hence the popularity of acrylic platters. Likewise I think a clamp is preferable to a weight as it doesn’t put extra stress on the bearing. I have a Rega P3 (2016) and I use an acrylic platter mat and a Michell clamp which both work well together, I also use a small spindle O ring to help with warped or dished records.https://uploads.tapatalk-cdn.com/201...2dbd326b0e.jpg
Sent from my iPad using Tapatalkhttps://uploads.tapatalk-cdn.com/201...c56a6a5877.jpg
