Schiit do a couple of equalizers that are well reviewed and don't break the bank. For example: https://www.schiit.com/products/lokius
Just read through this thread and agree with most said by others.
A new pre-amp is not going to do much if you have hearing loss of particular frequencies. I am quite familiar with this type of problem as my mother gradually lost her hearing in both ears over a period of 40 years due to Meniérs disease, for her she lost different frequency band at different times in each ear. The end result was she lost most hearing in the upper registers, 1000hz and above, 500-1000hz was about 40-60% and below was less impacted. This meant she could here men with deep voices reasonably well but women less so. As time progressed she was prescribed digital hearing aids, initially these were not than configurable but later on in her life they tuned them for each ear to boost the frequencies she was deficient in. But there is a down side in this, if she was in a relative quiet room for example holding a one to one conversation it worked pretty well, but if she was say out in a restaurant with lots of ambient noise and especially if there was higher frequency sound, which was common, then the amplification of this became an unbearable roar in her ears and she would have to turn the hearing aids off.
I thought the above would maybe help you to consider the issue you may face. I would suggest a simple and not too expensive way to see what impact the equivalent of a multi-band graphic equaliser would have for you is to use some software through your computer streaming some music. Audirvana used to and I believe still has the capability to select and boost/ or lower selected frequency bands, Roon also has the same capability.
You would need at least a DAC connected to your amplifier that you can connect to your PC/Mac with a USB cable, or alternatively pick up a RaspberyPi with HAT card or DAC that you can connect to your amp and then stream to Volumio(software) running on the RPI from Audirvana or Roon. However you do it you can play around with different frequencies and see it will work for you, and then decide if you want to splash out on a good multi-channel frequency analyser or not.
I hope that might be of some help. By the way if others are listening with your frequency settings it may sound quite horrible for them.
You can get a used two-channel professional Klark Teknik DN360 30 band 1/3 octave equaliser:
https://www.klarkteknik.com/product....odelCode=P0AGV
for about £150.
Even better than the 360 is a klark teknik kt410. Very transparent, I use one after my graaf 13.5bii, which you might want to add to your pre amp list, if you csn find one.
Have you tried hearing aids? Boosting the top end or cutting the bottom is going to leave the sound off for everyone else
Or invest in a top quality set of headphones with an eq in the chain. 5K should cover it given totl cans are around 4K.
Thinking on about this hypex based power amps might give you the sound you are looking for, i found my nord ncores gave gun fire in movies real snap
I've got hold of a Pass Labs XP30 , and am currently bonding with it.
Faster than the MBL , more like the Bryston in speed, but with bigger soundstage, and amazing definition , imaging and separation.
Currently head and shoulders above everything else I've had in the system !
This may work !
nice , thas a pre amp i would like to hear too
