They like peanut butter ;)
You need to spend some time tracking down exactly where they are entering. Once found block that and any other entrance off.
Usually the easiest spot for them is close to where they can access food. They are smart in terms of gaining access. It will be
like a busy highway to them, that they are using in the early hours of the morning. :eek:
Another observation if you already have them inside, you either need a cat or a dog to show you where they are, to best place traps
being careful your best friend doesn't get trapped too. Once they are firmly outside, you will hear them trying to gain access,
but will leave you alone once they cannot get in. They simply move on to the next house that has easy access. So block the holes they
are using off.... you should get some peace then.
Well that was a crappy night, I’m full of cold, went bed at 9:30; streaming nose for an hour, went to sleep at some point only to wake at 1 with Angina presumably because I couldn’t breath properly. Another hour and went to sleep propped up with 3 pillows. Awake again at 5, I think I am now more tired than before I went to bed. [emoji53]
https://youtu.be/T5N6GU95Dn0
Enjoy... :D
Yup, church at 9am - and I take a while to wake up and get my shit together!:D
Hope both you and Adrian (with colds) can get some sleep. When I have a cold, I often sleep better during the day.
P.S Apparently they taste like chicken. I like mine with their tails off.
You have to cook them thoroughly, I've heard scare stories about salmonella, which apparently they catch from chickens.
