Unless you still have your second converter, I guess I need something like this - https://www.audiophonics.fr/en/appar...g-p-10547.html
Just to add, my Chord cable (it was the turquoise one whatever that's called) was a big improvement over a cheap basic cable. Would like to compare to a Lindy.
Regenerate the USB signal either just before the DAC or use a DAC which does this internally. This is massively reduces the need and desire for special USB cables.
I wish USB cables didn't matter but also I find cost doesn't relate to best SQ. Ferrite chokes on the USB cables can help and probably are mostly what's needed. My best USB cable which came with a USB drive has with a ferrite choke.
Ferrite chokes are a bit of a lottery, they may work or not. They alter the impedance of the cable and affect the signal rise times so their use needs to be thought through first. If the designers of the end devices have done their jobs properly then there is no call for ferrite chokes on USB cables, just use a certifed cable.
I'm aware the ferrite chokes aren't necessarily a good thing but they are very inexpensive to try. I can't say whether the cable that came with my Toshiba USB drive is certified or not but presumably Toshibiba put it there for a reason - I don't expect they was the product to cost 1 cent more than it needs to.
If a cable is certified does it mean the cable is perfect? What I'm getting at is if the device at the end (or start) of the cable is horribly noisy then a certified cable is unlikely to do much to reduce the noise. Maybe a certified cable is just the starting point for such a noisy environment. What's at the receiving end should take noise in to account (hence the regeneration comment I made) but I suspect that multiple levels of cleaning will help in some situations.
Certification, I find can sometimes be like joining a club....you pays yer money and you get your stickyfoot.
There's some interesting stuff in the letters page of last month's HiFi World about digital cables. Upshot: they are more complex than most of us think.
Someone made the point about USB quality in general. My Chord Mojo has USB, coax and optical inputs and the USB is easily the worst of the three. My Fiio DAC does sound great through USB though.
Yes to meet FCC Class B
It means is meets the USB specification for whatever speed class intended. Yes it’s not going to fix a poorly implemented USB end device but then neither is a ferrite choke, as I said it’s a lottery, the variables are many. Sure try one as they are cheap and you never know you may strike lucky.Quote:
