adjust+ cartridge alignment software pro version for sale
i bought this to set my cartridges azimuth having done it its up for sale,it comes with the soundblaster external sound card,a small level and all leads to connect to your pc. a great bit of kit for the serious vinyl junkie.
have a look at the video to see it in use,being the pro version there are lots more things you can check and adjust,these include speed check,wow and flutter,tonearm resonance to name a few.
£310 posted
A+ is running on all Windows versions starting from XP SP3 and is a Windows only software but will run fine under Bootcamp or virtualized environment of Windows such as VMware Fusion;)
There is only one known and unfixable issue with Windows 10 starting from build 1609 that the PDF export function doesn't work anymore - still you can generate a report and print from the dialogue box into the PDF distiller that W10 has built-in and this works fine;)
As long as your sound card supports 96/24 sampling you are safe;)
A+ is available as Home or Pro. Pricing is 230 EURO for Home and 360 EURO for Pro outside EU.
Shipping options outside EU are 60 EURO with UPS Express Saver shipping. Included is the test record as well as the cables and the enhanced spirit level as can be seen in our youtube video. Please be aware that local import duties and taxes may apply on delivery when shipping outside EU.
Pro additional features are:
THD measurement
frequency response via Pink Noise
tonearm resonances
enhanced FFT-analysis
enhanced graphics export via clipboard
this is what i had from the Dr him self , regards pete that is £326,35 at todays exchange rate with warranty ,
16-07-2020, 04:21
karma67
wrong
this is the pro version which is 360 euros+ 60 shipping. i make that £381 then add to that the cost of the external sound card.
open to offers if you feel the price is high.
