HELP NEEDED! Fitting MCRU PSU
I bought a SL1200 with the PSU removed from the deck and placed into a seperate case. I've now bought the MCRU, LDA Linear PSU and so need to remove the decanted original PSU and connect the Linear. From what I gather from the enclosed instruction manual I'm going to have to solder a couple of wires.
Problem is I've never soldered before today. I do have a cheap soldering iron and a small pcb to practice on but am still wary of working on the deck.
Also do I have to remove the original PSU from it's seperate case, reinstall it and start from scratch with the new Linear supply or do I disconnect the whole thing and connect the new psu to the same place inside the deck.
Any help would be gratefully required.
