Hi all,
Ordered some of this a few days ago >
https://rover.ebay.com/rover/0/0/0?m...2F152150015281
Had them plumbed in for about 12 hours and I'm very pleased. Nothing to complain about just very good sound.
Very good stuff.
Hi all,
Very good stuff.
Looks similar to what Ive got
It’s so strange.... I also ordered these very cables a couple of months ago. I thought they were a bargain and very good.
Then....... another AOS member said..... have you tried Blue Jeans Cable ( effectively Belden cable made to Blue Jeans specification.) Just Stunning at the same sort of price point + USA IMPORT DUTY...... which is a bummer.
Peter
ive tried fisual cable twice,and twice it lasted about half an hour.
oli i beg you to try van damme's UP-LCOFC Hi-F i use the 4mm.
http://theartofsound.net/forum/showt...cable-reviewed
http://hifipig.com/van-damme-blue-an...es/#more-14566
Van Damme is excellent.
Audioquest FLX SLiP 14/2 for single wired speakers, 14/4 for biwired, £3.50 & £5.80/m respectively, I use them both in my 2 setups and find them excellent.
Not sure the one I'm using now is fisual tbh. The last one was. One Ive got now I got the tip from Brian. It's very good and it's not going anywhere. Ever
I’m certainly not going to get into a debate about speaker cable, as it’s a no, no.
I have 10k speakers and an even more expensive amp and ancillaries. Spent more on speaker cable than you can imagine £20 to £150 Meter. (And more).
At the end of the day, it’s what you like and what gives you the best sound to your ears.
Sorry all, but it’s what does it for you........ there ain’t no magic cable out there!!
Here endeth the Sermon.
Sorry in advance!!!
stuff im using is Fisual Super Pearl 2.5mm Speaker Cable
http://www.ebay.co.uk/itm/Fisual-Sup...item58944bb4ce
this is black but same stuff
They don't exactly 'oversell' it on the advert, do they? :D
Not so much of a bargain (although still sensible enough money), but if anyone's looking for a super-slim, discrete speaker cable, which can be hidden out of the way easily and sounds SUPERB, then I thoroughly recommend this stuff:
https://www.futureshop.co.uk/chord-sarsen-speaker-cable
I have it in my home-cinema system, which I also use for music duties, and it is really excellent.
