BSR turntable 1977-80
Sony PST1 direct drive (horrible thing) 1980-82
AR turntable (I still have this, but don't use it much) 1982-now
Roksan Xerxes 1986-2000, traded in for
Roksan Xerxes X 2000-now
ITT record player with built in amp and speakers that clipped on as a lid. 1974
Amstrad TP12D 1976 (Shure M55e)
Garrard DD130 1979 (Nagaoka MP11)
Townshend Elite Rock mk II 1986 still my go to TT (originally fitted with a DL110, but has had DL103, Goldring 1042, Sumiko Blue Point Special Evo III, VdHul DDT special and AT OC9 ? III). Arm is a fully modded (AO) RB250.
JVC JL A1 bought 2nd hand for 2nd system. (AT95e).
Rega Planar 3 1978 model with R200. I still have this.
Luxman PD264 without arm or dust cover. Saved this from going in a skip, it had got wet and the baseboard had warped, made a replacement baseboard from 6mm MDF and fitted a Hadcock GH228. Sill have this but the arm has been removed for...
LP12. I was always curiou about the LP12, so I bought one last year, no arm and basic power board, since bought a used Valhalla and am in the process of fitting the Hadcock to this. The Hadcock has a V15 type III with Jico SAS/SS fitted, had an OM10 on it at one stage.
As for the Luxman, I picked up a pristine Acos Lustre GST-1 for a song and have yet to fit this. I hesitate as the Acos requires a rather unusual cutout that nothing else will fit if I don't like it.
Dual CS505 in the early 80's.
Acoustic Research Legend in the mid 80s (loved it)
LP12 in early 90s (hated it!)
NAS Interspace Jnr in mid 90s (loved it)
VPI Scout now (love it)
Pioneer PL-12D
Revolver Rebel
Voyd Valdi
Voyd
Voyd 0.5 Reference
Voyd Reference
quite simple tastes by comparison to many of the previous answers
The Past:
Fidelity Music Master UA-2 (BSR changer)
Goldring Lenco GL78
Thorens TD 166MkII
Revolver Rebel
Thorens TD 160
Pro-ject 6.1
Thorens TD 280
Technics SL-1210 MkII
Rega Planar 3
Goldring Lenco G88
Spare Room:
Technics SL-150
Mission 775S
Braun PS-5
Pink Triangle LPT
Technics SL-DL5
On the rack:
Nottingham Analogue Spacedeck
Goldring Lenco GL-75
Very small compared to others here.
Technics sl2000
Heybrook TT2
Technics SP10
Sorry to say it, but listening to very little vinyl these days.
I forgot to mention two turntables I used for a short time.
Technics SL-5 (one of their "jacket-size" linear trackers) -- surprisingly good sound for something so dinky and could track literally anything regardless of condition (completely unfazed by warps and other issues). Was badly out of speed so I had to adjust it using the adjustment pots at the bottom (I had to buy a very long thin screwdriver to do this).
Luxman PD-282 -- a beautiful early DD turntable with an AC motor and an Acos-made tonearm that looked like Rega R200 but with a much better antiskating arrangement. I remember it for two reasons: 1) it was drifty even compared to other non-quartz DDs; 2) in their infinite wisdom, Luxman lined the inside of the plinth with aluminium foil for shielding, and a copper ground wire was screwed to this shield; this connection suffered from electrochemical corrosion quite badly which resulted in some very annoying ground hum. Of course, it was entirely possible to scrape off the corrosion, but it would give only a very temporary reprieve.
Let’s start off by saying I bought my Linn LP 12 in 1978 and now can say the only item left from the original player is the outer platter!
In the years since then I moved from the SME 3009 S2 arm moved on to a Grace arm the following year. In 1980 I had the 1st of 3 Ittoks fitted the first two after a couple of years developed bearing problems both replaced by Linn FOC. The last Ittok was fine when I sold it in 2004 on acquiring a Naim Aro which is still on my turntable.
I went through all the Linn upgrades till 1992 with the installation of the Cirkus bearing kit. Along the way went from the red button to the Valhalla in the early 1980’s. I went and had a Lingo mk1 installed when released in 1992?
When I had the Aro installed I couldn’t put my finger on it but I wasn’t happy with the Lingo went for an Armeggedon this to me was a big improvement.
2007 I moved on and had a Dynavector DV20L installed as my 3rd Karma was showing signs of wear. Coming to near retirement (2014) I had a Khan installed at the same time moved the DV20L to my son’s LP12 and had a Micro Benz Wood SL installed.
Soon after Tangerine Audio was formed Derek Jenkins ( RIP ) whom I’ve known for best part of 40 years and who has always looked after my turntable changed my Khan for a Karmen. Mark his able bodied partner told me that they had just developed a new sub chassis for the LP 12 so I had it installed in 2015 quickly followed by their new plinth which brings me up to date. In the same year I had a Kiseki Blue NS fitted so that is the story of my turntable.
Martin
My first record deck was a Christmas present around 1981/82?. It was an Amstrad with (if memory serves) a built-in amp with the controls running parallel with the tonearm. Next was a Sony Midi System with CD player, cassette deck and turntable.
Although these two record players are probably not classed as ‘proper’ turntables I think I got more enjoyment from them than any of the turntables which followed. It was all about the music then and not the gear…
My first ‘proper’ deck (bought early 90’s) was a Rega Planar 2. Cartridge was whatever came with the Rega then I moved on to Ortofon’s. My first proper Phono Stage was a tiny Creek.
I bought a LP12 second hand from my dealer. It had the classic afromosia plinth, Cirkus, Valhalla and a MK1 Akito arm. It didn’t take long before I fell down the rabbit hole of upgrades:
From Akito MK1 to Akito MK2 to Ekos MK2 to Ekos SE
From Valhalla to Lingo 2 to Radikal
From original subchassis to Keel
From Trichord Dino MK2 to Uphorik to Urika
Other upgrades include Trampolin, new platter and changing the afromosia plinth to a Walnut one.
After circa 15 years ownership I’d had enough of the upgrades and the feeling of never been satisfied. I was fed up of that nagging doubt the deck could be better, ‘’if only I had the latest upgrade?’’.
In reality the more I spent on it the less I enjoyed listening to it. The higher the spec the more clinical and uninvolving I found the prestation. Another important thing to factor in was my mental health. I’ve suffered from depression since my mid-twenties. I’ve had numerous triggers over the years and money, or the lack of it being one such trigger. A couple of years back I’d got myself into some debt (nothing major but enough to play on my mind). After much thought I decided to sell my LP12*.
Well Tempered Versalex: I’d loved the look of the Well Tempered decks for years. I went for a demo of a couple of decks, including a couple of the latest Rega’s (RP6 and 8) which were very enjoyable. We moved onto the WT Versalex and I loved the look straight away. Listening to the opening few minutes of Jeff Buckley’s Hallelujah the deal was sealed. Sublime spins to mind.
*I sold my LP12 to the dealer and bought the Versalex ( I also bought a Trilogy 906 Phono Stage which I love too) and cleared my debts with the rest of the cash. Upgrades…I bought a MCRU LDA linear power supply and that’s it.
I might try a few different mats as the original one does suffer from static cling.
So what does the future hold? I have no plans to change my deck but I plan to build my own Bigbottle Phono Stage later this year. Exciting times.
EDIT: Cartridges: I’ve only owned Ortofon cartridges, that trade-in scheme is hard to get out of. Laffin! I might try a Dynavector next though.
