Originally Posted by
Slawts
Hi Chris,
Thanks for the in depth response.
I can get it to work by playing around with it which is why I thought the contacts were possibly dirty.
It is a rotary switch and I tried vacuuming and then using contact cleaner.
I have a tech guy I use who also does work for the distributor as replacing/ changing or going down the relay route is beyond my skill set.
I was really trying to find out if there are any easy fixes that might work to avoid replacing etc. It is more the delay when it away as everything seems to take an age to fix.
I have read that WD40 can help with contacts but don't know id this is some old wives tale or not.
When it is on song this is the best preamp I have ever owned.
Cheers,
