These are the most affordable in the range. Never heard them. Just wondering have some members here tried the Blue? If so, any good?
S.
S.
It's pretty decent, I prefer it to the Black and Black2, although the Silver is more to my taste.
The Blue is quite bold and reasonably detailed, a bit smoothed over, it's a musical cable imo - i.e. it sounds like real music is being made. The Blacks are more obviously 'hifi' and I got a bit irritated by them quite quickly. The Blacks sound somehow 'wrong' to me.
If you can get the Blue used it's a bit of a bargain imo.
I use blue in my 2 channel av/hifi system- agree with Jerry lovely warm cable very music orientated less so hi-fi.
My son has black in his set up, I find it very good unlike Jerry.
All Colin Wonfors cables are pretty special.
Thanks chaps.
S.
Had Blue, loved it, so I assumed that Black would be better, don’t think it was, however, bought another set of Blue, having moved on the first lot, and somehow it didn’t sound as good as the initial batch, ended up keeping the Black, but, I’d thoroughly recommend the Blue.
If you’re still of an open mind, try some Van Damme Hifi speaker cable, I’m currently using the 4mm variation.
I have a pair of Ultra Blue here and they are perkier than the original Blue. Didn't like the Black but I'm blowed if I know what exactly I didn't like about them. Now the Ultra Blacks really got my juices flowing which soon dried up when I saw the price.
I’ve used the TQ Blue before and found it to be very good indeed... Never heard the black.
However, to throw a very cheap spanner in the works, the Van Damme blue cable is bloody brilliant IMO, worth trying if you’ve not done so already
I’ve used the 2.5, 4 and 6mm, currently using the 6mm that I bought off here last week, it’s solid stuff and not expensive at all. Some good plugs in it and away you go... It’s been a revelation to me, having used Chord, QED and TQ Blue in the past, I wouldn’t spend more now personally
Dont listen to ewa ls25....
Its the best Colin Wonfor cable I have heard.
Have it in my main rig -7m one side/2m the other....running it under a fireplace.
Run tq ultra jumpers- maybe not ideal!!
Aint cheap but IMHO end game speaker cable....
Thanks Tony Happy New Year to you all, oh try the not cheap LS50 I use it at home on my Oberon (22W/Ch) sounds to good for the likes of me and my music taste.
ALL HAVE A GREAT 2020 THE NEXT STRANGE YEAR IS 2121 I GIVE THAT ONE A MISS ME THINKS.
Shane I've not heard the Blue but have heard the Black and the Ultra Black.... the UB was an amazing cable... the standard Black was just 'ok'... so I'm guessing the Blue is just 'ok' at best...
I'm currently using Van Damme 4 x 2.5mm Black cable from Mark Grant and love it.... ok I'm going to be making my own speaker cable soon but if I were to recommend a good cable at a very reasonable price I'd definitely recommend the Van Damme Black from Mark Grant.... It's a bargain Shane and you really should give it a go....If not I'd also recommend Van Damme 4mm Hi-Fi Speaker Cable, also from Mark... I used that as well and it's also very good indeed and a complete bargain... Mark Grant makes some very very good cables.. you can't go wrong Shane... hope that helps
Wow 6mm? Does it bend?
