My Denon CD Player has euro 2 pin plug. The machine is set for UK voltage.
Can someone link me a decent 3 Pin Plug Adaptor. I know there's many on ebay etc. But any particular good ones worth chasing after?
Thanks.
S.
Thanks.
S.
Some would say you should use a dedicated Schuko wall socket (which would be illegal in a ring main). I don't; one of my CD players uses a Euro 2-pin plug of the same style as are used on electric shavers. For those one can buy special UK 3-pin fused plugs, which allow the 2-pin plug to be fitted inside.
https://uk.farnell.com/powerconnecti...cal%20adaptors
http://www.farnell.com/datasheets/83...SAAEgIAwvD_BwE
Otherwise, just use a Europlug to UK plug adaptor readily available from most hardware shops.
Now sorted. Thanks.
S.
