Hi Steve
yeah tried it several times but cant get tge last bits out. lol
Sent from my SM-G950F using Tapatalk
Hi Steve
sometimes resoldering and desoldering it again will clear it.
ok thanks will try that , have to be tomorrow now lol going to the rugby now.
Try to apply the iron tip to all 3 legs and pull it out quickly to avoid cooking.
Put a large blob of solder across 2 legs to start with if your tip isn't that big.
well i was hoping to reuse the component. Not sure there would be enough leg left to resolder if i did that.
Personally, I'd cut it off. I have a few spare bits, so I'll check the stock and if I have some I'll send you some down mate.
The amount of heat you've put through the FET trying to remove it may kill it too. Then you may have to remove it again!
They aren't expensive either to be fair. We've all done that though, wrong part or wrong way round. Learn from it and slow down a little. The excitement to get it done takes over sometime [emoji6]
Yeah i have a spare but will try Alans way 1st as it would be good practice for me to try. If I get frustrated I can always go the more " surgical" route [emoji16]
