I use a Hydra type plug so it all earths there, including the TT Its always quiet, but I admit earthing is another black art.
I have had a shuffle around in the rack and found positioning of the Paradise critical. I bought an Opus CD player in the hope of better distribution on my rack (2 half width cases, transport + PS) but the Paradise wasn't happy till it was on the shelf alone.
I found it susceptible to hum from adjacent to rather than above/below, I s'pose motors and torrid have differing electromagnetic fields?
Parcel Contents:
Stock No Quantity Description
6833402 25 MRS25 Resistor A/P,0.6W,1%,270R
6833386 50 MRS25 Resistor A/P,0.6W,1%,261R
6834180 50 MRS25 Resistor A/P,0.6W,1%,240R
6833348 25 MRS25 Resistor A/P,0.6W,1%,232R
6833360 25 MRS25 Resistor A/P,0.6W,1%,249R
well if that lot doesn't get the cartridge loading bang on i'll give up :D
Lol, at Mr dogs we found 10 ohm to be easily identifiable on a low impedance cart. My benz LP is a honey badger, it doesn't give a shit, 200-800r will do.
lol am i being to obsessive??:lol:
Quote:
Originally Posted by
DiveDeepDog
Which cart, Jamie?
audio technica art-7
I’ve got Art 9, but my AT37 is probably closer spec to your 7? 0.1 output, 3ohm internal resistance, you really appreciate how quiet the Paradise is, looks like I could do some tweaking
Hi Jamie
I see your getting a few Vishay resistors-should get your loading spot on with that lot mate:)
Steve...
Mark, I have some RCA plugs with double screw terminals on the back, less hassle than soldering and a quick way to get dialled in.
these spring loaded could be even easier
https://www.amazon.co.uk/Maxhood-Spe.../dp/B077MH6TD2
mmmmm, solid silver coils for the output buffer, cos, why not?
https://c2.staticflickr.com/8/7804/4...596eb9c0_b.jpg
