New GrooveMaster Armrest Clip in Stock
We now have the new GrooveMaster tonearm rest clip in stock at Ammonite Audio, and available for existing owners of all GrooveMaster variants, including Timestep. It's an easy DIY fit - you simply undo the bolt holding in the existing arm rest post, then simply replace that with the new clip, using the same bolt. The new clip can be bought from our shop here priced at £35 including VAT and UK postage.
All new GrooveMaster tonearms bought from our shop will be offered with the clip pre-fitted, at no extra cost, unless the customer specifically asks for the old arm rest 'post'.
https://ammonite-audio.co.uk/wp-cont...-3-600x600.jpg
https://ammonite-audio.co.uk/wp-cont...est_Clip-1.jpg
