3 Attachment(s)
Tonar Woodgoat Cleaning Brush
I've wet cleaned less than 30 LP's since buying this at the end of June this year - its the dual row wooden brush.
Seems to do a good job but, after rinsing it yesterday one clump of bristles fell out. I left it to dry and another 2 have were ready to drop out. Not good for £20 worth of brush.
I've asked the retailer whether it has a guarantee and they are looking into it.
Have look at the pictures and you can see the bristles are secured by steel wire that has rusted - not great for a wet cleaning brush.
The only reason for posting this is that many of you use one - so my advice is to check yours but gently tugging on each clump to make sure they are well anchored. Rusted steel wire on a soft vinyl LP is going to do some damage. Luckily for me I did not damage a LP.
