Fingers crossed
Fingers crossed
Ok so hooked up and no joy , measures the same no valve glow, bummer . I need to have a look at the top of the board maybe and see if it has the same short but will need dismantle some bits 1st so no time tonight. Never mind but it's 1 fault out the way;)
Tune in next time pop pickers for some more electrickery adventure... :D
Spent a couple of hours with the MM today found 3 shorts to sort out, a couple not very obvious at all. I dunno what numpty put this together but there's no quality control around these parts :D
Thanks , it does help when you find something though. Feels like you are making progress , however small it is[emoji846]
Sent from my SM-G975F using Tapatalk
So no I haven't given up on this , too busy at xmas to do anything with it bit a dry day yesterday and some time meant I could cut the side of the case. test dry clamp before gluing, 18 mil birch ply. [emoji41] seems to fit ok [emoji846]https://uploads.tapatalk-cdn.com/202...7c76808f27.jpghttps://uploads.tapatalk-cdn.com/202...9e013a1b18.jpg
with the lid on glue next.
https://uploads.tapatalk-cdn.com/202...a4907da72d.jpg
https://uploads.tapatalk-cdn.com/202...561da29596.jpg
Sides glued and trying for size , seems to fit so feeling pretty pleased. [emoji846]https://uploads.tapatalk-cdn.com/202...a830ed28fb.jpg
coming on :)
Andy:
What make are those corner clamps?
