As per title. Second hand not new. Budget max of £400 but preferably less.
Either single box or transport/dac.
Thanks.
Thanks.
Sony XB940QS. Should be under a ton. Plays SACD too.
Pioneer PD-S703 or similar should be around £50
Leaves room for a Beresford DAC
Anyone have opinions or experiences on Roksan CD players?
Nice onkyo sacd on the wam, worth a look
A few years back I was shopping for an affordable but decent CD player for my daughter. After a lot of research I settled on the Marantz. I won’t swear to the model number but maybe a 4004?It was about $400 new. And from all the reviews I could find it had a higher reliability rate than most other brands. After I got it home, I did a side by side sound quality test against my Sony ES, and it was so similar it was hard to tell the difference. That’s been many years back, and it’s still working well. So, I’m sure you can find an even higher model Marantz used for £400, well worth consideration.
Russell
