Hi - does anyone use an App to keep a record of all their DVD/Blu-Rays along the lines of Discogs? (ie scan in bar code to capture details).
I read that Discogs was being developed to allow this but I can't seem to get it to work?
Cheers
John
Cheers
John
Hi John
Try https://www.collectorz.com, you can use it totally web based or use there apps for Mobile devices or computer, Mac and Windows. I use it for my Vinyls and CDs, to record what I have, what I spent on each and where they are stored, also on iPhone when out shopping so I can check I do not double purchase. There is a scanner that integrates on Mobile. On the computer version you can add you own fields to record info, i.e. "Last Cleaned", "Date Last Played"
Cheers
Adrian
Thanks Adrian - that looks exactly what I want.
Seemingly I can also transfer my Discogs database across too.
John
