i played around with these in the late 70s. I believe they were made by Furukawa, who made cables for many other brands.
I still use Hitachi 102 ssx speaker cable, still very happy with it and no intention of changing it.
Hi Barry,
Sorry but did not visit and not sure who is Josie.
Photos are my qax-112 and new 6nax-210 ... look for qax-112 if you like qax-102 since more of all the positive "presence" or "naturalness" mentioned here aka midrange. Dun bother with the elusive 6nax-210 as it is near impossible as it was 4 times of almost 40k yen and not many sold 30 yrs ago like the 10k qax-112 or cheapest qax-102.
Last that I should mention ia that both qax-102 and qax-112 should be with original factory tetminated ofc rca ... I see a lot reterminated one and they are probably with intention to mislead that they are original.
Cheers.
Richard
Attachment 27849Attachment 27850
Furukawa and Hitachi differs:
Is it the mid-1980s, the heyday of audio?
It was a time when it was widely recognized that the sound changed with a cable.
In Japan as well, major electric wire manufacturers enthusiastically developed and each was a masterpiece.
Broadly classified, the direction is to remove impurities from conductors and improve the purity of materials.
The other is a vector that improves signal transduction loss by reducing boundaries at the copper crystal level.
(Later, materials that have pushed these two directions will be developed.)
The former is typically Ortofon, Acrotec, SAEC, etc. (8n / 7n / 6n, etc.)
The latter was famous for Furukawa Electric's "PC-OCC" and Hitachi Cable's "LC-OFC".
Both Furukawa and Hitachi supplied OEM products to each company, and there were examples of adoption by many manufacturers.
Unfortunately, both FURUKAWA and HITACHI have stopped production for management reasons.
I think the contributions made by the two companies to the audio world have been enormous.
I had a pair of these in the early '80. I thought them no better than other cables I was using at the time. They are of so-called "semi-balanced" construction; that is they use a double core screened cable, where the signal return is connected to the screen at one end only. They are thus directional so that the screen is connected at the source end (with the arrows printed on the cable's outer jacket points away from the source and points towards to the load).
By chance I have just unearthed the Hitachi data sheet that came with the cables:
HITACHI LC-OFC INTERCONNECTING CABLE
SAX-102 is a high grade interconnecting cable for Audio and Video equipment, using LC-OFC (Linear Crystal Oxygen-Free-Copper) as conductor.
LC-OFC is the most suitable material for Audio and Video purposes.
This product is a pin-cord made with SAX-102 for use with Audio and Video systems.
FEATURES
1. Clear sound with minimal distortion.2. Superior electrical distortion3. Durability due to inner plastic molding of the pin-plug4. Use of 24k plated pin-plugs
CONSTRUCTION AND CHARACTERISTICS
Conductor: Size 0.2mm2Conductor: Stranding 50/0.08mmConductor: Diameter 0.65mmInsulation (Polyethylene) Diameter: 1.65mmInner Jacket (Polyethylene) Diameter: 4.00mmShield: BraidJacket (PVC) Diameter: 6.00mmConductor Resistance (at 20oC): 80 Ohm/kmCapacity (at 1 KHz): 50pF/mImpedance (at 10 MHz): 65 Ohm
Hi Barry,
Found answer to your query ..
No, sax-102 is lower grade to qax-102 that is preceded by qax-112.
Original price of 1m was about 5kyen vs 7kyen vs 10k yen respectively.
Cheers.
