Originally Posted by
JohnG
I am keen to begin with trialing different materials for isolation feet.
I have access to this material in 300mm x 300mm pads, which I was considering to use under the Monoblock Amps. It would potentially have ended up in the TT Isolation Investigations as well.
I see it is used as Sub Plinth Foot and Sub Foot Support in your set up.
How did using this and increasing the positions of use in the support set up, show up as a improvement in your the system.
I recently took my SP10 to a friends to trial out a few different MC's, after a few tracks we tried out different footers, initially by placing the needle on a Non Spinning LP, and having a light knock around the Stand and Sub Plinths and then the TT Plinth.
After swapping out a few different materials and then combining materials, between the TT and the Sub Plinth, a combination of a thin foam as a base, a 10mm Blackwood Billet , another thin foam, a 10mm Blackwood Billet and a Soundcare foot making contact with the TT Plinth, produced a foot that was largely unaffected by the Light Knuckle Knocks on the Stands and Plinths, when compared to some of the earlier ones.
On the first replay, following the last combination of materials foot being put into use, there was a immediate audible difference, Bass was much more clean,taught and cut off very precisely, I am sure there were other benefits offered as well, but maybe not so obvious.
I am curious to learn if a certain type of tweak is beneficial to all, or whether they are room and stand dependent.
