Reiver Acoustics Millburn MK ii
I commissioned Colin to build these for me last year to use whilst I was renting a small flat near the site I was working at that didn't have room for my OB's. Shortly afterwards I moved on to another project so these had very little use and were put into storage- I would doubt the drivers are properly run in yet.
The cabinets are made with 18mm Baltic Birch Ply, I chose Crown Cut American Walnut for the veneer which I think looks rather spiffy.
The driver is a 10" coaxial unit from Monacor- the SP-310CX. The bass/mid cone is rated at 96db and the 1" tweeter at 105db, so these are very easy to drive and with high power handling. the crossovers use high quality components- Jantzen 1% tolerance Superes resistors, Jantzen Z-Caps together with Jantzen Iron core (with discs) and Air core inductors.These retailed on the Reiver website at £1250, I'm looking for £700, which I think is a very good price given these are virtually new.
I would be keeping them if I had a use for them as they are great sounding speakers, but now I'm living with my partner I need to get rid of some gear. I'll be advertising some other items in the near future.
Demo is no problem - I'm located in Leeds. I'll deliver within 50 miles free, further within reason for cost of fuel.
Some pics-
https://i.imgur.com/ZRgxZAS.jpg
https://i.imgur.com/M8hTV0i.jpg
https://i.imgur.com/mFnZct8.jpg
https://i.imgur.com/Q77Xeol.jpg
https://i.imgur.com/jnUZdqn.jpg
