New Lounge System. Options?
Hi,
All being well, I hope to be starting work again soon after being unemployed for over a year now. Yay! :)
With that taken care of there are some things that my wife and I want sorted. She's made a list :rolleyes:. One of those is a new system for the lounge. Before I go on, I know that possible solutions for this may be found in other threads but I'd like to start afresh if I may.
At the moment, in the lounge, we use a Monitor Audio i-Deck iPod system. This isn't entirely satisfactory because it's not that convenient to use as you have to select your song choices on the ipod itself. You cannot browse the library with the remote. So, a change is required.
My hifi upstairs is fed from ALAC files on my mac via an Airport Express and my old minidisc's dac. So, one option would be to get another AE and stream to the i-deck downstairs. The i-deck has an analogue input. This would also require the purchase of an ipod touch to access and browse the mac's iTunes library, effectively serving as a remote control. However, I'm not totally satisfied with the stability of the wireless network. I'd be peeved if it lost connection, or suffered drop outs.
Another option is to buy a new cd based system, but I'm reluctant to go back to having cd's cluttering up the place.
A further option, and this is where I may need help cos I know little about them, is to buy a new streaming device, such as a SB touch. Apparently, this can run from a HD library? I have a spare HD that I could copy my library to. I guess this could be used in conjunction with the i-deck amp and speakers (can you tell I'm still on a budget?) or go with new amp and speakers, perhaps even powered speakers.
Lastly, I wouldn't say no to a PS3. If I were to get one, could that be used in this system somehow? Can it hold an iTunes library and output to active speakers?
I know there are a lot of options, so I'd appreciate it if you could help me get my head round it. It's one of the few things on my Wife's list that I'm excited about! :)
Edit: More options. A Logitech SB Boom, or similar, or even the new Apple TV used to serve music.
