Meitner Audio Releases the MA3 Integrated D/A Converter
We are extremely pleased to announce that Meitner Audio are releasing the first of their next generation products. Introducing Meitner Audio’s ground breaking MA3 Integrated D/A converter. The MA3 combines Ed Meitner's proven world-class sound techniques from their beloved DA2 V2 and DV2 converters, with network audio streaming functions from their popular and simple to use NS1 Streamer - creating one sleek, affordable package to serve your greater enjoyment of music.
The Meitner Audio MA3 Integrated D/A Converter will be shipping out to us next week for delivery to our authorised dealers.
The Meitner MA3:
16xDSD MDAC2™ DACs coupled with our proprietary MDAT2™ DSP
VControl™ volume control used in our EMM DV2 converter
Supports DSD128/2xDSD, DXD and MQA®
Built in network streamer for music streaming service integration
16xDSD MDAC2™ and MDAT2™ DSP:
The MA3 employs our MDAC2™ fully discrete single-bit, 16xDSD, D-to-A converters, coupled with our MDAT2™ DSP which performs real-time transient detection in addition up-conversion of all incoming audio. VControl™ maintains the input signal without re-quantization allowing for complete transparency at any volume setting, wide attenuation range, and no loss of audio resolution.
USB Isolation, MFAST™ and MCLK2™:
The USB interface includes EMM’s proprietary hardware galvanic isolation. MFAST™ our high-speed asynchronous jitter removal technology working in tandem with our custom built clock (MCLK2™) provides jitter removal from all digital sources.
Built in Network Streamer:
Connect to high resolution streaming services like TIDAL, QOBUZ plus support for popular music services like SPOTIFY, DEEZER, vTUNER etc. UPnP/DLNA support for network and NAS file playback, ROON READY and ROON ENDPOINT functionality plus direct USB audio file playback. Designed and manufactured in Canada, simply connect it directly to amplifier(s) and speakers of your choice and enjoy! The MA3 is the perfect integrated digital hub for any high end system, regardless of budget.
[IMG]
Key Features
Up to 24bit/192kHz & DSD support over all inputs: USB Audio, AES, TOSLINK, COAX and Network(RJ45)
2xDSD (via DoP), DXD (352/384kHz) over USB Audio
Full MQA® unfolding via USB Audio and Network(RJ45)
Proprietary & discrete dual differential D-to-A converters (MDAC2™) with Meitner Digital Audio Translator signal processing technology (MDAT2™)
MFAST™ instant signal acquisition and jitter-free performance
Proprietary asynchronous clocking system (MCLK™)
VControl™ high resolution volume control
Galvanically isolated USB Audio interface
Network streaming with UPNP/DLNA and ROON READY/ROON ENDPOINT functionality
High resolution, Tidal and Qobuz and popular, Spotify, Deezer, vTuner plus many more, streaming audio services support
AAC, AIFF, ALAC, FLAC, MP3, WAV and WMA audio file playback
USB service port for future software upgrades
IR remote and serial port for wired remote control
mConnect app for network control on Android, IOS and tablets
Newly designed strong and elegant all-metal chassis
Power Supply:
Power factor corrected
Universal 90V-260V, 50/60Hz
Power consumption: max. 50W
CE Approved
[IMG]
Specifications
Digital inputs:
AES/EBU, S/PDIF COAX, TOSLINK, USB Audio and Network(RJ45) supports up to 24bit/192kHz and DSD
USB Audio also supports 2xDSD, DXD (352/384kHz) & full MQA® decoding
Network(RJ45) also supports full MQA® decoding
Stereo Analog Outputs:
Balanced (XLR)
Unbalanced (RCA)
Output voltage:
XLR outputs: 7.0V (+19.1dBu)
RCA outputs: 3.5V (+13.1dBu)
Output impedance:
300 ohms balanced (XLR)
150 ohms unbalanced (RCA)
Dimensions:
W x D x H: 435 x 400 x 92mm
Weight: 7.43kg (with remote control)
Designed and Manufactured in Canada
https://www.emmlabs.com/images/meitn...-3_Beauty1.jpg
https://www.emmlabs.com/images/meitn...-3_Beauty4.jpg
https://www.emmlabs.com/images/meitn...-3_Front_1.jpg
https://www.emmlabs.com/images/meitn...-3_Beauty3.jpg
https://www.emmlabs.com/images/meitn.../MA-3_Back.jpg
Meitner Audio PRE Stereo Preamplifier
We are pleased to announce that the Meitner Audio PRE preamplifier has launched and shall be making its way to UK dealers soon.
The Meitner PRE preamplifier is designed with Ed Meitner’s philosophy that an analog preamp acts as the heart of every music system.
Built on the heritage of the reference EMM Labs preamplifier, the Meitner PRE incorporates a contactless switching system and discrete dual-balanced signal paths. Its proprietary software-driven analog volume control ensures zero signal bandwidth degradation over the entire volume range, while its pure class-A power stage can effortlessly drive cables and loads. With a high-efficiency, low-noise power supply system, the Meitner PRE delivers class-beating performance that will keep you listening to your music collection well beyond curfew.
Our team is committed to designing products that enhance user enjoyment while providing a secure listening experience. The Meitner PRE exemplifies this with its user-friendly balance control and volume preset system, and by providing DC protection to the rest of the system. It is this philosophy that has earned us our customers' continued loyalty.
The Meitner PRE has 3 pairs of stereo analog inputs:
1 pair balanced (XLR)
2 pairs single-ended (RCA)
along with two pairs of stereo outputs:
1 pair single-ended (RCA)
Both balanced and single-ended outputs can be utilized at the same time for versatile configurations such as connecting the balanced outputs to the main amplifier and the single-ended outputs to a subwoofer or headphone amplifier.
The Meitner PRE preamplifier upholds the Meitner legacy of being a class-defining value proposition, with its surprising performance and evenmore surprising price point
3 pairs of stereo analog inputs: 1 pair balanced, 2 pairs single-ended
2 pairs of stereo analog outputs: 1 pair balanced, 1 pair single-ended
Contactless switching
Discrete signal paths
Pure class-A power to drive cables and loads without degradation
Proprietary software-driven analog volume control
User-friendly control system featuring 3 volume presets per inputs and balance control
High-efficiency power supply for silent and eco-friendly operation
DC protection circuit
RS232 interface for system upgrades and remote commands
https://www.emmlabs.com/images/meitn...E_Beauty2L.jpg
https://www.emmlabs.com/images/meitn.../PRE_Front.jpg
https://www.emmlabs.com/images/meitner/pre/PRE_Back.jpg
https://www.emmlabs.com/images/meitn...y_Remote_R.jpg
https://www.emmlabs.com/images/meitn...E_Beauty3L.jpg
