Originally Posted by
Mandryka
If you do get Gradients, do try (though it may be very hard) to get the MT Crossover, or have it in mind to programme your own crossover. That's the weakness on the old gradient system, I believe they've relaunched the subwoofers for the ESL 63 and they have an improved crossover now.
If you add subs you are effectively destroying the point source image of the ESL 63s, and the result can sound splashy. That's one reason why the MT sub is better, because with patience you can delay the sub sound w.r.t. the main speakers, and so compensate for the slight difference in position in space. It sounds like it's not going to matter, but for me, it really did matter.
I also have supertweeters with them, which I also think are well worth trying (especially because you can get them on a free trial basis from Townshend)
I suspect that the Krell will be very good with the ESLs. It's upstairs and the ESLs are downstairs and it weighs a ton . . . .
