Caiman SEG - a few questions re PS, cables, FW upgrade...
Hello everybody,
I am finally evaluating to get a DAC whose use would be to convert and play FLAC off of my Mac (either a MacBookAir or a MacMini), AppleTV4, Sony TV and Sony CD-player, given price, input options and, above all, quality I am onto the Caiman SEG whose reviews are very good even here in Italy :)
Questions wise, I read here and there about the problem when switching bitrates, so far seems like it needs an upgraded FW chip, is this correct? Since there is an used one I am awaiting a reply for I suppose I have to go the upgrade route while, probably but not sure, bought new off of Beresford it could be already updated, which is which?
PS, the one on sale might come either with the standard wall PS or with an upgraded one, since the owner hasn't reply yet I am wondering, should I get it somewhere else, which are the voltage and current requested off the Seg to get the best out of it? I read 12v standard up to 15v for increased quality :scratch: would anybody tell me, again, which is which and sources to buy a good quality linear one here in the old EU? I own a switching one which I use once in a while on my HAM equipment but I hate the slight noise it does and I regret the times in which there were only linear ones, a 12-15v 5-10A one should not cost that much, I don't like whistle and bells, just on-off switch, black face to match the DAC and that's it, input appreciated.
Cables wise, I would need two optical ones to connect both the ATV4 and TV to the DAC (oooops, I just found out ATV4 has no optical output so it gotta go through HDMi-TV-DAC), which are the parameters to care about for a good working one (I don't trust in cables magic, just a decent construction one with no gold or diamond connectors...); would be fun to try also to play CDs through both the old Sony CD-P X505ES (with an upgraded output stage) converter and the SEG just for the sake of it, which is better, optical or coaxial for the purpose? Least, USB wise, same as above, to stream from the Mac to the DAC what should I look forward at?
Thank you all for reading and for your input
Giovanni
p.s. the DAC would be connected to an AR SP-9 preamp which drives a twin KT88 Aeron AP890 power amp which then fires my old JBL4311B, the GyroDec is awaiting restoration but hopefully soon spinning again!!!
