Analogue inputs - good ADCs and streaming?
I've been following several of the threads about DACs with interest, but I wonder about going the other way. Initially I was thinking about digitising some LPs, and I should be able to do that using my current ADC, but then I though that if that, which also can do DAC, is not as great quality as for example the DACMagic and the Caiman, then presumably there is scope for a good ADC.
What do guys here recommend?
Ideally I'd quite like to be able to digitise an LP, but not only that, also to stream it across a network, so that I could put the disc player in another room. Discs would be played from there, and digitised to hard disc, but at the same time would be played back via a suitable DAC. I don't know how much of this is feasible.
I'm guessing that the first step is to obtain a high quality ADC - or at least higher quality than I have now. Then perhaps use some form of internet radio streaming tool to broadcast across my network. Could I also get this to do FLAC encoding on the fly at the same time? How easy would it be to "tee" in the writing to the hard drive?
