Well what can I say ....my ears are in heaven .
Looking good. Have you tried them with tweeters on the inside edge?
Hi Macca ,
No I haven't tried that , is that the correct placement then ?
There's no correct way but it will be different and you might prefer it.
I use mine with the tweeters on the outside but, as above, there is no right or wrong (it's certainly worth trying both). Glad you are enjoying these wonderful speakers :) (interesting stands and speaker grills too).
Cheers mate , I will try them with the Accuphase too at some point .
I was always told that if you lay down your speakers tweeters are placed at the outside.
I think with bridge monitors tweeters are supposed to be on the inside edge.
Well the Yamaha sales literature does indeed show the tweeters on the inner side .
The serial numbers on mine end in an R on one and an L on the other. Assuming these markings mean Left and Right it would suggest tweeters on the outside.
Yes, that is true - my assumption was that it was when facing the speakers as if to listen to them.
That's also true of mine Mark and following your suggestion, I prefer the tweeters on the outside.
I think which is preferred is partly room dependant and the positioning of the speakers relative to the side walls and listener.
