2 Attachment(s)
Celestion Ditton 25 and 44 Refurbs
Hi everyone,
I recently acquired a pair of Celestion Ditton 25s and 44s that need some work. I've seen a few threads on here about these speakers so I thought I'd start one, and hopefully get some advice.
They are both in good condition - the 25s are really good, the 44 cabinets have a few scuffs and scratches.
So I've started by cleaning and re-oiling the cabinets. They are currently drying after a couple of coats:
Attachment 16544
Something looks dodgy with one of the tweeters on the 25s, but I've decided to concentrate on the 44s first.
I'm really impressed with how these sound. Really full. But there are times when something is not quite right, although it's hard to identify what.
So the next thing I want to do is upgrade the wiring and capacitors on the crossovers (they are the older non-PCB type):
Attachment 16545
The date on some of those capacitors is 1972 - so I think they are due for a change! I've never done any internal work on speakers before. There's so much conflicting information on what replacements to use (I've spent hours reading through threads on here and other forums). So I'm just going to go for exactly like for like replacements:
For the woofers (the black caps on the right), 72 uF Alcaps.
For the mids (the 6 uF at the top and 24 uF at the bottom), I'm not sure if both these existing caps are low leakage. Does anyone know for sure? Neither has LL written on them anywhere. If they are, I'll probably go for Mundorf ECap PLAIN. The exact values aren't available though, so I'm thinking I'll make the 6 uF with 4.7 + 1.5, and the 24 uF with 22 + 2.2. Or I could get exactly a 6uF Alcap Low Loss.
For the tweeter, I might use ClarityCaps. Does anyone know if they are worth the extra cost over cheaper polypropylenes?
I attempted to remove the crossover board, but I found my trusty 25W soldering iron (Antex from Maplin) was not very effective. I'm wondering if I really need to buy a more powerful soldering iron, or persevere with the one I have, but I don't want to damage any of the components I'm not changing by overheating them.
Any tips or advice would be great!
Thanks!
