Restoring a Roksan Xerxes (original)... Wow! And no plinth sag anymore.
I have recently restored my Roksan Xerxes, which I had purchased in the UK during my MSc studies in 1989. The exact model year of the turntable is unknown, but I estimate it to be around 1987.
So what I did is the following:
- Changed the blobs, which were rather stiff, with new Roksan blobs X3bi
- Cleaned and re-lubricated the main bearing with a few drops of oil
- Changed the belt with a new one from Origin Live
- Changed the tonearm (perviously Rega RB300) with an Audiomods Series 5, especially tuned for the new cartridge
- Changed the cartridge (previously Dynavector DV10x4 MkII) to a MusicMaker III
After all that, I sat to listen some of my old records. I have to admit that over the last years, my Roksan was somewhere in a corner, because at some point one of my kids had accidentally damaged the cantilever of my Dynavector cartridge and I had not done anything about it since then. It seems that I had grown accustomed to the ease-of-use of the CD and downloadable music from Spotify and Apple Music.
Well, it took only a few seconds of playing a record on the restored Xerxes again to remember what I had been missing...
Compared to the CD, the soundstage was wider and deeper, more palpable, more real, more convincing, with better separation of instruments and voices. Everything was much better. And the supposedly annoying record pops and clicks were so few that I would simply ignore.
Yes, people who still favor analogue sound are not crazy. And even if they are, I am happy to be one of them. Again!
Motor placement on the bottom plinth of Xerxes
Although Origin Live recommend placing their DC motor on the top plinth with a single screw, and although the OL DC motor is quiet, still there are inevitably vibrations that may be carried from the motor to the cartridge through the tonearm.
So I took the decision to experiment a bit and placed the motor on the bottom plinth, as the original Xerxes (AC) motor used to be. With the only difference that I did not allow the motor to rotate around its axis.
Initially, my impression was that the sound had become somewhat 'smaller' in comparison to when the motor was placed on the top plinth. Then, a few tracks and a few minutes later, I realized that the sound was somewhat cleaner and more precise and that gave the above-mentioned impression. It was perhaps the lack of motor vibrations and hence added energy around each note that made things smaller; but also more precise.
So, I will continue my experiment by having the motor on the bottom plinth, but I think that this is how it is eventually going to stay.
I do not know whether any other fellow forum member has had a similar experience with the two alternative motor placements.
Quote:
Originally Posted by
legb4rsk
Hi,the motor only spins on it's axis when the platters spins up apparently to compensate for the torque needed to start up the very heavy plater. Once up too speed it stabalises & remains in place.
That's not quite right I'm afraid. The rotating motor isn't to do with startup torque - it doesn't help this aspect at all and the AC motor used would have no difficulty overcoming the static inertia of the platter anyway. The actual idea is to compensate for variable stylus drag and momentary variations in motor speed. As you say, once up to speed the motor is held stable, in equilibrium, though the spring holding it is under tension. For the idea to work the strength of the spring must be matched to that of the suspension and drive belt compliance - that is to say that it should be significantly less resistive than either (which it is). The concept is thus; the platter and motor are supposed to stay in a fixed relationship in terms of rpm and linked by the drive belt. However, is the rotation of one alters (due to variation in stylus drag or motor flutter) it will react independently initially, stretching the belt until the belt is able to compensate and regain the equilibrium. The idea is that instead of the forces acting to stretch the belt they will cause the motor to rotate by the same amount so maintaining even belt tension and so even speed. It's rather an interesting, but controversial, idea. Speed stability is one of the foundations upon which the success of the Xerxes was based though and so it certainly doesn't seem to do any harm (which on first thought one would rather expect it to).
I must tell you that the concept I expounded was not my own but that of Touraj Moghaddam designer of the Xerxes, I just phrased it for the purpose of this thread. Personally I have taken a different path. There is however an issue I am personally aware with with the mechanism that you propose; motor torque is proportional to load - during steady running friction is very low and load is also approaching zero as is torque. When the load does vary there is significant compliance surrounding the magnetic field within the motor, this compliance must be compressed before motor torque can increase and this injects delay into the system.
When you write 'extra strong motor' you presumably mean one capable of developing high torque. However, that torque only exists when under load, when loaded by the static inertia of a heavy platter at startup for example. What few seem to realise is that as load approaches zero so does torque - the maximum potential torque of the motor makes no difference in such a situation and once up to speed a turntable platter does offer very minimal load if the platter is balanced and the main bearing is low friction, the mass of the platter is irrelevant.
Placement of OL DC motor on the bottom plinth
Well, it is now evident that the placement of the Origin Live DC motor on the bottom plinth (or chassis), instead of the top plinth as proposed by Origin Live, provides the following advantages:
- better fine detail
- lower noise floor
- slightly more realistic overall sound, especially with voices and separate instruments
The only tradeoff is the somewhat 'smaller' sound, but if I had to choose I would go for the motor on the bottom plinth.
I wonder whether there are other users of the OL DC motor or other motors who have made the same experiment of motor placement.
