Utter beginners guide to digital music set up needed please !
So, I have a pc with lots of music stored in WAV format. I am soon to have a Caiman DAC. I also have a stereo.
I have a really bad internet connection, making listening to or downloading online music difficult.
I want to listen to the music on my pc via the stereo, and know nothing about squeezeboxes and the like.
What do I need and how do I set it all up ?
Is there some sort of guide, or can anyone help me out here ?
I do not need music all over the house, as I have a volume control and no neighbours to worry about but some sort of random play feature would be wonderful (my iRiver HP40 is wonderful for that when travelling) so can anyone tell me, in basic terms what does what, and why buy this or that.
Anyone willing to put in the time it takes to educate one as far behind the times as I am ?
complete computer music beginner
what do you need?
well it sounds like you have everything, you just need to connect it up.
you don't mention a home network so i'll skip that bit for now.
1. put the computer somewhere near your amplifier.
2. plug a usb lead into the pc and put the other end into the caimen dac.
3. connect the dac to your amp with two regular phono leads into the aux input on the back of the amp.
4. switch on the pc, dac, and amp.
5. select the usb option on the dac.
6. select the aux on the amp
7. open your player of choice, if you don't have one download itunes for windows.
8. itunes will ask if you want it to search for music, click yes.
9. adjust the volume slider, upper left, to about halfway.
10. adjust the amp volume to about 25% usually about the 9 o-clock posn.
11. select the album you want and click play.
12. you can now adjust either itunes or amp volume till your happy.
13. sit back and enjoy.
the only problem you may have could be between step 6 and step 7 where you may have to alter the sound output settings on the computer to enable usb output, but usually it's automatically done by the computer, which is described as 'universal plug and play'.
i hope this helps and i haven't missed anything critical.
good luck
steve
