Calling All Upgraded Technics Owners
I have read all the posts about the improvement upgrading your Technics 1200 series will provide. And all the heated discussions it has caused and that's not necessarily a bad thing.
I for one would love to be able to compare my current number 1 table, Pro-Ject Perspective with 9 cc Carbon Fiber arm, with an upgraded Technics, I have two Technics which are both stock standard, a nice SL1700 and a SL 1200 Mk2.
So I think I have a way of settling this.
Why don't all those with upgraded Technics 1200's post what upgrades they have and what turntable it replaced, carts included.
This way we have a sort of yard stick as to what is better than what.
My standard Pro-Ject Perspective easily beats out my standard Technics tables.
I am really considering upgrading the SL 1200 Mk2 with a Timestep PSU and a Jelco Arm, probably the feet as well.
If these improvement would let my SL 1200 Mk 2 surpass my Pro-Ject then I would have no problem selling it, I got it for a song anyway and may even make a profit.
So lets hear it folks what did you do to your Technics and what did it replace and how much better does it sound?
Dont' neglect the quality of your headshell or lead wire
Hi Dave (DSJR),
Quote:
I'd also very respectfully suggest that the standard headshell is fine for higher-compliance cartridges...
"Fine" it may be, but what would you prefer: "fine" or excellent? It's about dotting the i's and crossing the t's. In my system (even without using a low-compliance DL-103) I can easily hear the difference a better headshell makes. The stock headshell is flimsily constructed, made from poor quality materials, and quite resonant. None of those are good qualities. After all, the headshell is what you're coupling the cartridge to. Upgrading a detachable headshell may seem like 'small beer', but quite simply, in a genuinely high-resolution system the small details matter :)
Quote:
I'd also say that a couple of inches of headshell wire is the last thing you need to worry about when dealing with the standard arm, as the possible resonance problems when using moving coil cartridges would make a FAR bigger difference to the final sound.
I completely agree; hence why I recommend upgrading from the stock arm when going for an MC cartridge. *However*, it's all about those small details again - only this time they're not quite so small...
If one considers that those couple of inches of headshell wire are the first thing that the (delicate) signal sees when outputting from the cartridge pins, then they are very important because any information lost at that point cannot be retrieved further down the chain. Think of it along the lines of how poor quality interconnects can 'hobble' the signal from a CDP or preamp. The length of wire may be different but the effect is the same.
Being the T/T geek that I am, I've experimented with just about every set of detachable headshell wires on the market (and also most headshells), and I can tell you that there is a noticeable difference in my system between the bog standard crap supplied with the Technics headshell and, say, the solid silver Ortofon lead wires I use with my NOS magnesium headshells.
All I'm saying is don't underestimate the importance of dotting the i's and crossing the t's when optimising your system, as it can often mean the difference between hearing the 'full picture' in all its glory, or merely a snap-shot of the real thing. Going the extra mile in this way, in my experience, usually pays dividends.
