Budget cartridge/headshell/phono-stage advice needed
Hi,
I've recently purchased a Pioneer PL-71 direct drive TT.
Providing it doesn't get smashed to bit's in the post, this will be my first TT.
As I've never owed a TT before I don't have a phono stage and I know very little about TT's in general.
So I need some advice on what I need to get the PL-71 up and running.
I know it's probably going to need some switches and pots replacing but I think I'll be ok sorting that out. I'm planning on leaving the TT as standard as possible for now and just getting it working. From what I understand this is often the best approach with this model anyway which is one of the things that attracted me to it. I like simplicity.
I think the one I've bought is completely standard, so I think I just need a cartridge, headshell and phono stage.
On the subject of phono stages, I hear the Cambridge Audio 640P is great value for money at around £50-60 on ebay. So I was thinking of getting one of these to get me started. Can anyone think of anything more suitable/better for under £100.
When it comes to cartridges and headshells I don't know where to start. So what would be a good combination for around £100 for the pair? I would consider stretching to £200 if it meant the results would be considerably better.
If it helps, I listen to a wide variety of music so I need to make the PL-71 a bit of a jack of all trades I guess. My favourite genre is rock though.
Many thanks. :)
