Beresford TC-7510 or TC-7520 for my system?
Good afternoon everyone,
I was hoping someone could give me some good information and opinions about my personal system. Here is my current audio/music setup:
WAV Files
Iomega ScreenPlay HD Multimedia Hard Drive
AudioQuest Hawk Eye S/P DIF
Primare SPA21 Surround Amplifier
AudioQuest Rockefeller Speaker Cables
Vienna Acoustics Strauss Speakers
PS Audio Power Port AC Receptacle
Furman Power Station PST-8 D
Shunyata Research Sidewinder Power Cord
I am considering the addition of:
Beresford TC-7510 or TC-7520 or TC-7520 with the LM4562NA
Kimber Kable Hero Interconnect Cables
If I theoretically had the option to buy a brand new TC-7510 at a severely discounted rate, would my system instead sound better enough by purchasing either the TC-7520 or TC-7520 with the LM4562NA to make the higher price worth while?
Thank you everyone and I really appreciate your help!
Sincerely,
-Adam Wright
The reason I think I need a DAC...
Quote:
Originally Posted by
Stratmangler
I have just looked at your component list (all looks to be good kit, I might add), and TBH I'm a little intrigued by your desire to include a TC-7520, especially as the AV amp already does conversion duties.
Sorry, I should have spent the time looking things up on the 'net earlier.
Chris:scratch:
Chris, thank you for your response. I agree it would be better to avoid an external DAC, but here is the issue I am having:
The Primare does a good job with the DA conversion, but the processor is slow to lock in a digital signal. So one of two things happens when I play music using a hard drive: 1) Either I miss the first 3-5 seconds of a song, or 2) I hear the first 3-5 seconds, then I miss the next 5 seconds or so.
The only solution I can think of is to convert before reaching the Primare. Can you or anyone else think of a different or better solution? I would be thrilled to skip adding another component or step to the system. And I am assuming I should avoid using the hard drive's internal DAC.
Any help or suggestions would be appreciated!
Thank you again!
Sincerely,
-Adam:confused:
DAC Synchronization Issue
Stratmangler
Hi Adam
I agree with you on the above point.
The rest is puzzling to say the least. From what you describe there is a definite synchronization issue, but from which end (Iomega or Primare) ?
Are there any GUI interfaces that you can address the Iomega with ?
I would think that the Primare is pretty a well closed and locked shop !
Possibly the only way around the problem is to deal with signal in the analogue domain, in which case I retract the question.
Confused ?
I am !
Chris:confused:
Chris, both the Iomega & Primare are connected to my television to access the Menus, Options, etc. But I have not seen anything for either component that will address this issue.
I have reason to believe the issue is with the Primare because I have the same problem if I use a CD player or DVD player with a digital connection to the Primare. I do not have this issue when I use analog connections, but then I am sacrificing audio quality by using the DAC from the CD player or DVD player.
Suggestions anyone...please???
-Adam
