Battery Power for Touch and BM2
Since the combination of Logitech Squeezebox Touch and Beresford Bushmaster 2 is so popular, I thought I'd start a new thread for those looking to maximise the performance of the two combined, using an inexpensive 5V/12V battery and charger. This setup provides battery power for both the BM2 (12V main output) and Touch (5V USB output), dramatically increasing their sound quality, while using only a single charger to keep it all charged and running.
Ingredients
- Logitech Touch
- Bushmaster 2
- 20,000mAH 12V/5V battery as originally linked by Stan, from Ankaka or other sources
- 14.5V charger supplied with the battery, or better still a quality 14-15V linear power supply like my Paul Hynes PR3, with 2.5mm DC plug
- 2.5mm to 2.1mm DC power cable to supply the BM2
- USB to 2.5mm DC power cable to supply the Touch
- Belden 1694A co-ax cable such as provided by Mark Grant
- EDO (Enhanced Digital Output) app for the Touch
- Remote control app of choice for phone or tablet
I modified the USB phone power cable supplied with the battery by cutting off the accessory end and soldering a 2.5mm DC plug for the Touch. Note that the BM2 has a 2.1mm socket but the battery and Touch use 2.5mm sockets. The included DC cable has a 2.1mm tip suitable for the BM2. I will make up custom DC cables from better wire in due course.
The neat trick here is that a single charger effectively keeps the battery charged and supplies both units. A linear supply (in my case connected to my regenerator) sounds even better than the supplied switched mode charger. It can be easily disconnected for ultimate battery-only listening, where there is enough charge available for a good day's listening.
Further enhancements are setting the BM2 to LED sleep mode and using the EDO app (this is really mandatory) to send digital output only and disable the analogue outputs. Also, set the screen to timeout when playing music, or use the TT3 tools to disable it permanently and use a remote control app such as Squeeze Remote for Windows 8 or iPeng for iOS.
Finally, wired ethernet from the PC sounds preferable to the Touch's wireless networking, which struggles somewhat.
http://farm4.staticflickr.com/3752/1...cc94350e_o.jpg
