Changing to 14V for TA-2021 Mini-T Amps
I bought a cheap 14V 5A switched mode power supply in order to test my assumption that the TA-2021 will sound better when run at 14V compared with the TA-2020 Mini-T amp that runs at 12V. One of these from eBay:
http://www.ebay.co.uk/itm/1806883876...84.m1497.l2649
Moving from the 12V to 14V adapter, there is a definite improvement in focus and clarity and a reduction in congestion when the wick is turned up and things get busy. Bass definition is also improved and there is just a little more kick. This when used with my small Fostex-based PC system. I would say that where the TA-2020 running at 12V was pushing against the limits of comfortable running in nearfield listening, the TA-2021 running at 14V has sufficient headroom for anything I want to play.
Very pleasing, and has confirmed that building a proper linear PSU is well worth the effort. I shall be building a 14.5V PSU based on Paul Hynes' PR3iEHD module when it arrives. More when I have all the parts.
