Hi Martin,
Yes, the Furutech sockets work and provide a notable sonic improvement, but they're really just for adding the 'icing to the cake', as it were, once every other aspect of your mains set-up has been sorted, therefore to be honest, your money would be much better spent on something else, like this if it's still available for sale:
http://theartofsound.net/forum/showt...797#post341797
Later, you could then upgrade the sockets for Furutech ones, as I have on my Mark Grant mains block. Correct me if I'm wrong, but I think the sockets on your current block are fixed?
If you really want to fiddle with wall sockets, then in my experience, the best sound-per-pound option is The Missing Link EPS-100 Ultrapure Silver plated (un-switched) wall sockets, shown here:
http://www.the-missing-link.net/new_page_1.htm
If you scroll down, you'll see some measurable proof of their sockets having considerably lower resistance than bog standard generic sockets from B&Q, or whatever, and even supposedly high-quality ones from MK! On the left is the measurement from the Missing Link socket, and on the right, one from from MK:
http://img823.imageshack.us/img823/2...llsockets2.jpg http://img703.imageshack.us/img703/179/wallsockets.jpg
I've carried out those sorts of measurements before, with my friendly electrician, when we were optimising my mains set-up, and trust me you can hear the sonic improvements of lowered resistance!
Right down at the bottom of the page are prices, which I consider are very reasonable (considerably less than the Furutech stuff). I would also go for the matching 13A plugs, which are likely to be a good physical fit with the partnering wall sockets.
Try that, and you'll be a happy bunny! :exactly:
