Paul Hynes PSU for Caiman DAC
This is part 1 of my rebuild of the Beresford Caiman DAC and my original external power supply to incorporate Paul Hynes' power supply regulator modules. These will replace the SuperTeddy in the external PSU box and the Dexa regulator modules inside the Caiman.
Many enthusiasts, and I am one of them, believe that great audio components are practically defined by the quality of their power supplies. This is my attempt to go all-out for the best performance possible from the already excellent Caiman, using power supply modules made by Paul Hynes.
Showing the PR3 +16V regulator module for the external PSU and the two S17LNS2 regulator modules for the +5V and +12V internal voltage rails (coming in part 2).
http://www.mtc.me.uk/images/P1000472.jpg
Offering up the parts in my stripped-out PSU case and things are looking tight. As it turned out, the transformer was the incorrect voltage for centre-tapped rectification and needed replacing. Its replacement (0-15V, 0-15V, 50VA) was slightly smaller - phew! I snuck a Nichicon MUSE capacitor into the external capacitor connectors in the hope of better high frequency reservoir performance.
http://www.mtc.me.uk/images/P1000474.jpg
The PR3 now attached to the front panel. Heatsinking is not really an issue due to the small load current drawn by the Caiman (as it turned out, there is precious little heating up at all).
http://www.mtc.me.uk/images/P1000476.jpg
Adjusting for exactly +16V output. No need to worry about on-load adjustment as I doubt the voltage drop is at all significant (my Caiman has passive coupling caps with no op-amp board so there is precious little +12V draw). That LED is bright!
http://www.mtc.me.uk/images/P1000480.jpg
The completed external PSU in place and operational. Those old Hi-Fi News Flux Dumpers are perfect for the job.
http://www.mtc.me.uk/images/P1000484.jpg
So how does it sound? Considering I haven't given it much time to burn-in, the answer is significantly better than the SuperTeddy. I am hearing a wealth of tiny details and aural cues, bass is tighter and the overall soundstage is well defined and very transparent. Sound quality from Sky HD over optical and Blu-ray over co-ax are equally superb, as well as CDs using the Sony as a transport. The Caiman is not normally used for CD playback in my system, but I would be very happy indeed with it, it really is a DAC in another league altogether when fed from a power supply like this.
The SuperTeddy is well known for being an ultra low noise regulator design, but to the detriment of current and instantaneous peak delivery. The PH PR3 design features heavily in transient power delivery and is no slouch in the noise stakes, either. It seems that the Caiman, and particularly the Wolfson 8716 DAC, benefits from being fed by a meaty, over-spec'd PSU.
Ancillaries: Multicomp MCTA050/15 0-15, 0-15 50VA transformer; Kimber PBJ DC cable; Maplin project case, really very bright blue LED.
Part 2, replacing the internal regulators, will come soon.
Paul Hynes PSU for Caiman DAC Part 2
I've now installed the +5V and +12V regulators inside the Caiman.
Showing the PCBs after installation of the two PH regulator modules. It's a tight fit but it can be done and I used double-sided sticky pads to hold them in place.
http://www.mtc.me.uk/images/P1000485.jpg
This is a complete list of the mods made to these boards:
- All audio path electrolytics replaced with Elna Silmic II
- Main 10,000uF reservoir cap replaced with 2 x 10uF Panasonic film caps
- PSU protection diode replaced with a wire link
- Op-amp board and socket removed and replaced with 2 x 2.2uF Auricap coupling caps
- 3-pin regs replaced with +5V and +12V PH modules
The sound quality after replacing the Dexa regs was a smaller but further improvement in refinement and focus. I noticed especially a very high level of transparency with female voice and increased heft in the bass.
Listening to Barcelona from Jewel's Spirit album usually tells me all I need to know about sound quality. Her beautiful but powerful voice soars now with no hint of harshness, underpinned by a very potent bass line that is more textured than ever while having no remaining hint of boom. It's quite a performance and the Caiman sounds frankly fantastic playing it.
All in all a very satisfying modding experience. I'm going to leave well alone now, let it burn in some more and enjoy the fruits of my labours.
