SME 309/IV/V arm-boards on SL1200
Just a quick question for any folks using a SME 309/IV/V arm on a SL1200.
Do you experience any VTA issues ? I mean any issues getting the arm low enough so that the arm tube is parallel to the record surface.
The reason why I ask, is that I am contemplating putting a SME-IV arm on my SL1200, but I am worried it may not work.
I have noticed looking at images of SME magnesium arms, with some of the popular carts out there e.g DL30x and AT33, that the arm is always at its lowest position in terms of VTA (and this is where the arm board used is one with a recessed centre section).
I was hoping to use a MN copper arm-board (my deck has the MN bearing, but not the support plate), but since it does not have a recessed central section, I suspect it will not work.
Appreciate the thoughts/answers from folks already using an SME arm on their SL1200's.
Kind thanks in advance
