This morning
This morning
Superb, Andre - bring it on everyone! :)
Who's having it the worst (or best, depending on how you look at it)?
Already posted mine but I'll put it here too. Been unable to get to work at all this week so far. :(
Nice one, dude. Any chance, chaps, we can have them show automatically as 'full-size' pics (640 x 480 for message boards) instead of thumbnails?
Cheers! :)
We have less than "diddly squat" on the snow front down here. :(
Dunno how to do that Marco.
Select the option in Imageshack or Photobucket for 'resizing for message boards', rather than showing it as a thumbnail, before uploading the pics from your hard drive. You will simply be given a different forum code to post.
I presume you are hosting your images through an appropriate site, rather than simply uploading them directly from your hard drive onto the forum?
Or if you want, I can sort out the pics for you :)
No,I was just taking them with my phone and emailing them to my computer.
Ah - that's your problem... You need to import them from your phone onto the hard drive of your computer, then host them through the likes of Photobucket or Imageshack.
Do you know how to do that? If not find out.
If you look here at the Imageshack site, you'll see what I'm talking about:
http://imageshack.us/
When you've done all of the above, you simply click on the 'Browse' button, and a window will pop up showing you all the pics stored on your hard drive.
Simply select the ones you want to use, and then click on 'Open'. Then where it says: 'Image Options, Resizing' on the Imageshack window, select '640 x 480 for message boards'. Then where it says: 'Add Label to Thumbnail?' in a drop-down window, select 'no'.
Then click on the big blue 'Upload Now' button.
After a few secs, a page will appear which shows various URL codes. Look down the list until you see 'Forum Code', then simply copy and paste the full URL code shown there in brackets onto the reply box here, on whatever thread you want, and submit that code along with any text you're sending.
Simples! You'll get much better results with your pics that way :)
P.S Andre, that also applies to you! ;)
Helsinki last week. Note the under pavement heating, piped from the underground parking tunnels. Now that's having your act together!
http://theartofsound.net/forum/pictu...&pictureid=377
http://theartofsound.net/forum/pictu...&pictureid=378
