The present & the future...
With the ever present possible threat of extermination from a certain Dalek :lol: i thought i'd better get some pics up of my present system & future components :)
First of all the whole system is in a state of flux, there are bits & pieces all over the place & not where they should be. I had some serious issues with some weird earth loops that totally messed up the firmware on a couple of DVD players with HDMI connected. I fact one player (Denon DVD 2910) will no longer output via HDMI or DVI :( Right now the AV components are sitting in front of the TV & i'm listening to mixed down stereo on a couple of Mission 780s...
To the HIFI.
First up here is my DIY rack, there are quite a few components so i had to make it 2 components wide. The whole thing is made from 18mm MDF apart from the shelves which are 15mm. I designed it so that every shelf is adjustable & nearly every component sits on it's own paving slab (suitably painted) & these are isolated from the shelf & rack via 12mm thick felt in each of the 4 corners. There are glass doors on the front of the rack & these have rather nice seals to prevent dust ingress. Unfortunately it doesn't work too well right now as i need to install some fine material (like speaker grille cloth) on a frame & cover the ventilation holes at the base of the rack. The door frames were made using secondary double glazing fittings available from DIY stores, i cut the glass to fit.
If you are wondering about the colour scheme it's painted this colour to match the walls :drinking:
http://i939.photobucket.com/albums/a...leftside-1.jpg
Notice there is a rather large hole near the base where a DVD player should be sitting :doh: Also another rather large hole where a Pioneer CTF950 cassette deck will be residing when i get things as i actually want them.
Here's the right hand side. Again this will all be taken apart as the HK AVR5500 will be removed along with the Classe DR5 & Extron video scaler & other bits will be going in instead :)
http://i939.photobucket.com/albums/a...ightside-1.jpg
My pride & joy, the Krell DT10 transport. I picked it up off of fleabay just as the recession kicked i hard for about a 20th of the original new price :) Works beatifully & makes my previous transport (Theta Data Basic) sound like it was a midi system :eek:
http://i939.photobucket.com/albums/a...rellDT10-1.jpg
Moving on to the modified Yamaha NS1000M speakers. Well i guess they really shouldn't be called that any more, the only common denominator is the crossover & original drivers. The 12" is now inside the main enclosure in a 4th order bandpass alignment, this covers from approximate 30 - 110Hz. The 12" is fed directly from one channel of a Musical Fidelity P150 at present. The other channel drives a 7" Audax which is connected to where the yam 12" would be on the Yam crossover & the other drivers in the usual positions.
http://i939.photobucket.com/albums/a...odified1-1.jpg
http://i939.photobucket.com/albums/a...odified2-1.jpg
The crossover is built into the stand & wired up to the speakers. I used some fairly heavy 6mm brass threaded rods to do the connections. The enclosures are 36mm thick & extensively braced & weight in at about 140lbs with the drivers. To keep the enclosure as narrow as possible the 12" was tilted to an angle approaching 45 degrees, it's accessable via a removable panel on the rear of the speaker.
I'll get some more stuff up a bit later, loads to do unfortunately ;)
Bests to all, bye for now...
