Hi all,
I've just downloaded Jriver and have set up a Media Center. Its finding Volumio ok, but it's only playing the first 3 seconds of a track before moving on to the next track
I've tried everything and just can't figure out why!!!
Any help?
Hi all,
Any help?
could be a bit rate problem between the 2 units.. a driver issue or try and see if there is a newer build
in jr click tools, options.. then audio device, device settings and then dsp and output formats... Need to check your pi too. try them all on standard 44/16 first. there can be quite a few device options so avoid kernal one. start with direct sound then wasapi etc.
if a update is avail it usually says so at bottom left
done some tests with 24 and 25. Mine is doing similar except just playing 5 seconds then stopping. As JRiver used to work with my RPI i can only think its a volumio issue, but I could be wrong. No issue using audirvana to rpi tho. cancel that i have an issue with audirvana too now :doh: must be volumio
Just tried them to my oppo dvd player and it works fine so its a volumio thing. must have come from the last update i did recently. as it was working last time i tried it. but if it sends to oppo then it should go to the pi too. knew i shouldnt have updated when it was fine :doh:
i JUST DID A FACTORY RESET ON VOLUMIO. working now with audirvana as far as i can see.
