Originally Posted by
UV101
Hi Neil, definately a bit of an overzealous generalisation. I've definately painted a worse picture than I intended to! :doh:
My problem is that I have taken my machine much further than I intended to and to that end, the original sound is indeed, wooley and shut in!
I find the TDA very analogue sounding and much less edgy than later dacs. It is an excellent base for modification and when done right, will be right up there with pretty much anything. I've played with several chipsets and I've yet to better and fully sorted discrete regged TDA chipset.
There are plenty of fairly cheap CDM4 transport based machines with the TDA1541A that respond very will to a handful of well placed mods. Although the CD50 is not the best example for modding (plastic chassis), they are very cheap and can respond very well (I've done a couple now, lots of space for off board goodies), but as you say, you wouldn't start to mess about with a CD94 just for a laugh unless you planned to do something quite spectacular with it!!!:cool:
