Do you still get slight lag with it cabled?
Your Airport is connecting directly to your hifi using RCA cables? If so, you' haven't begun to hear how good your airport can sound. My airport is connected to my dac via a mini-toslink cable, this one;
http://www.lifatec.com/toslink2.html
Now, regarding the options you are considering, and the fact that the airport is limited to 44.1 Khz. I would;
1. Connet my iMac toslinked to a DAC. Same cable as the one mentioned above. The iMac's optical out can stream up to 24/96 data. the maximum recommended length of a toslink cable is about 5 meters.
2. If option 1 isn't good enough then I would try the hiface solution.
CD
Your iMac (check to make sure as there were so many iMac models) has a 24/96 digital output. The AE will never do that. So yeah, forget the AE in your situation.
I use and airport express for 2 reasons;
1. My Mac is very very far away from the stereo.
2. My Mac does'nt have any suitable digital output, like yours. I could use RCAs, but....no:)
Your question about using ethernet or wireless for the airport express, there is no lag. If you have good signal strength with wireless then it doesn't matter wheter you use wire or wireless with the AE, the performance is the same. As mentioned earlier, my wireless signal is weak and therefore unreliable.
CD
You must have very long runs of ethernet cable running around your house then!
Old thread...I know. I finally got a jitterbuster. Found a used Theta TLC. In the first week I had it I found it was very sensitive to power. My unit has the standard wall wart, not the beefy upgraded PSU. When plugged into a shared power strip, it didnt sound that good. Powered up from a wall outlet brought out the good sound.
The improvement was substantial. Much reduced digital glare and significant bass improvement. iTunes outputs bit perfect to an airport express from a Macintosh, so all the TLC had to do was straighten out the data, which apparently it does quite well. Through a DIY friend I am building a beefy PSU for it. That should really tighten things up.
CD
Nothing like coming back to an old thread :) I use a Monarchy Audio DIP24/96, non upsampling ;) The difference it makes isn't subtle, it's just plain obvious :eyebrows:
Wouldn't be without it tbh, best cash i spent on my digital system (apart from the transport which was a real bargain) :)
