hi Andre
They're cheap Chinese jobbies no brand. Do a search on ebay for corner clamps and you'll get a few options - 4 for less thank a tenner. Had em ages they are ok and do a job.
Are they a true 90 Degrees? Ive got a couple of old Marples jobbies but they can get really expensive..
ok finished the side and front with some fillet to keep inplace. Ill drill them and use some s bolts for the fixing to the base and side. https://uploads.tapatalk-cdn.com/202...d8074d8299.jpghttps://uploads.tapatalk-cdn.com/202...0010048064.jpghttps://uploads.tapatalk-cdn.com/202...e96534e850.jpg
Sent from my SM-G975F using Tapatalk
With the top fitted for size , still need to cut to size and drill valve and ventilation holes. then ill veener it and add some trim to the edges. Another new adventure! https://uploads.tapatalk-cdn.com/202...ee2d44b666.jpghttps://uploads.tapatalk-cdn.com/202...908d984957.jpg
Quck update , sorted the wiring after some fettling by th egood mr FB who added a couple of gridstoppers to one of the valve bases . https://uploads.tapatalk-cdn.com/202...5459f29c41.jpg
I drilled some hole in the base for ventilation, thye will sit under the pcb. https://uploads.tapatalk-cdn.com/202...cebf4c8e07.jpg
After being reminded of what valves I should use [emoji16] There was glow stuff so I started on the socketshttps://uploads.tapatalk-cdn.com/202...7cceeccbaa.jpghttps://uploads.tapatalk-cdn.com/202...6fe7a0ce58.jpghttps://uploads.tapatalk-cdn.com/202...1aedb7117f.jpg
Quick check for earthing etc and so now for a test out, All works! I need to tidy up the wirimg a bit but all sounds good . [emoji846]https://uploads.tapatalk-cdn.com/202...6b93182969.jpghttps://uploads.tapatalk-cdn.com/202...f0037f452a.jpghttps://uploads.tapatalk-cdn.com/202...ff562f998c.jpg
Like it - good work :D
