Hmm.. that is still a job to do with mine actually. I can solder but... wow... them little things are really small.
Unfortunately my neighbor didn't have any success - any takers ?
Hi Marco, are the Z-foil's the same as Vishay foils? (which I think they are)...
FYI I was having my MDAC upgraded by JW a couple of years back to the then latest upgrade of L2 (I've lost track of where he is now on his PFM thread). Whilst he had my DAC he discovered the benefits of the foil resistors...and offered 2 additional upgrade paths...
One known as 'Toy' (after the forum user who first went for it), using 4 foil resistors in the most important areas (where I can't recall)
The other known as 'Fusion', using about 32 foil resistors...
At £16 a pop for the resistors I went for the 1st option...;)
As my IQaudioPiDAC is in a case (kitchen duties), I doubt I'd be able to shoehorn them in, even with the aid of a professional
EDIT; Looks like they were used in the analogue signal path, so perhaps not the same as your mod...
http://mdac.referata.com/wiki/Main_Page
All sorted now with the Z-Foil upgrade and sounding great !! I would attach a photo if i knew how.
http://uploads.tapatalk-cdn.com/2016...c4072aebeb.jpg
Sent from my LG-H850 using Tapatalk
Thanks for the heads up on how to upload the photo guys!!
Looking good, Terry.
I need to find someone to do mine me thinks.
Does anyone know if you can power the PI/IQAudio DAC+ another way rather than the micro USB socket? I'm looking at recasing mine and wondered if there is another way. I have read that you can power the pi via the GIPO pins but not sure if they are available once the dac board is mounted.
Thanks
