Anybody know of a decent but affordable A to D convertor. This is not to archive records but to connect an analogue output to a DAC.
mostly ive found an analogue to dig sounds pretty similar with any, bar the really expensive. and possibly not worth extra.
I am using a Projet DS2 ti connect my turnable.
Pretty happy with it.
https://uploads.tapatalk-cdn.com/202...12240e1f8e.jpg
Sent from my G8341 using Tapatalk
Thanks for the suggestions. I've got one of these on the way and as it is digital only wondered if an A to D would allow the connection of my record deck.
https://www.audiophonics.fr/en/netwo...4-p-14639.html
It's not for transferring vinyl, just for playing it live.
Also found this which might just fit the bill.
https://www.project-audio.com/en/pro...-box-s2-phono/
Can I just double check with you guys with the Pro-ject DS2 USB. I understand you can use it to record digital copies of your vinyl to a computer but can you use it plugged into say a RPi and play the vinyl via the Pi to a DAC?
not via pi(unless it has a toslink).. just straight into dac is fine.. it has a toslink for that.(i dont think you need a pc to do that if memory serves, 99% sure) can also do another analogue source like a cassette or r2r.. phono has 2 inputs as well, so you can have 2 tt's or 2 arms; even mixed mm and other mc.. its a nice machine. mine is the silver and wood one but i think same as one in pic above. they are 475 new now.. were well over 500 originally.. might sell mine. not sure.
https://uploads.tapatalk-cdn.com/202...1616c80d98.jpg my one
Thanks Grant that's very useful. The Audiophonics DAC does optical in so it looks like it should work. If you want to sell let me know.
its a very good phono stage, and the buttons and indicators are a joy.. saves a lot of messing about. if you do ever get one, and your interested in recording, buy vinyl studio pro.. it is a fab program..
