I recently found that headshell terminal connectors , are not all one size!!
I purchased an Aiwa headshell ,(which I was going to fit my AT95E /Shibata stylus onto, and into my Aiwa TT ) only to find that both ends were not a standard 1ml fit!!
The headshell side were smaller than the regular size I was used to,and the cart side bigger !! :scratch:
I have a replacement set ,and I thought , ok ,just solder the different ends to suit. Not as simple as that as the replacement set are covered with heatshrink ,and I dont want to mess them up either really!
Could I find 4 standard sized connectors ,anywhere ?? Does this make any sense , or do I need a padded room ?
Oh ,I also read elesewhere , that some folk crimp the terminal up a bit to suit , but all thats going to do it bugger them up IMO
