Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: Mike new plinth????
    Default Mike new plinth????
    This is very very embryonic but i've spoken to Mike and asked about the possibility of a brand new plinth replacement. I highlighted to Mike that I'd like a single billet design and thus eliminating rubber base plate, inner aluminium chassis and the top plinth, hopefully we could get rid of the strobe button and pitch slider. It'll be expensive due to the soaring costs of aluminium but I think it would probably be one of the single biggest upgrade for the 1210. Mike has a design ready but would like feedback from other AOS'ers regarding the feasability of such a project. OK guys its up to you.
    I'm ILOB.
    Its worth ago for sure but I think only worth considering if you done everything else.
    Basically what you done is created a whole new TT
    I'd be up for it, but I don't think that a single type of material (least of all metal) is the answer. In my view, it would be a recipe for achieving a rather clinical sound, especially as the Techie already has those tendencies. For me, wood would have to feature somewhere in order to add some warmth.
    The most sonically effective plinths I believe are those which are designed around a 'sandwich' effect of different materials, such as slate and various hardwoods, as what one is striving for is effective isolation, but not at the expense of one material dominating with its contrubuted sonic signature.
    This is where the 'sandwich' idea would come in, as one is harnessing the effect of combining the isolation and sonic properties of various materials.
    I'd therefore be open to suggestions on the design of a suitable plinth along those lines
    Turntable: Heavily-modified Technics SL-1210MK5G [Mike New bearing/ETP platter/Paul Hynes SR7 PSU & regulator mods]. Funk Firm APM Achromat with Nagaoka GL-601 Crystal Record Weight. Isonoe feet & boots. Ortofon RS-212D tonearm with Denon DL-103GL, in a Denon PCL-300 headshell, fitted with Funk Firm Houdini and Kondo SL-115 pure-silver cartridge leads.
    Have you seen the review of Dr. Feikharts turntable in hifi world? This is pretty much a sandwhich of wood and aluminium. I've also looked at several plinths for my 301 and a multi-layered wooden sandwhich seems to recieve glowing reviews.
    Yes, that's why I think it works! The 'sandwich effect' with wood and metal (I'd also put some slate in there, too) is definitely the way
    I'm not sure though if Mike can work with wood or slate as well as he can with metal...
    I'm ILOB.
    I had the super scoutmaster which was a wood aluminium sandwich and worked well but many think arcylic and metal sandwich is better it might be worth speaking to someone like James Heriot
    MartinT Guest
    The Technics composite sandwich is an excellent design. Don't be too certain that an alternative design will actually sound better.
    I'm ThinkingOfHorns.
    Quote Originally Posted by John View Post
    I'm using an early VPI HW19 base (well I think that's what it is!) with my DP-6000 to great effect. It uses a 'sandwich' type top plinth which I think is made from steel plates & a fibrous type material, not sure what it is tbh, could be wood, tufnol, cork? It's very heavy & pretty dead to a knuckle rap! I bought it to get the DP-6000 up & running, but am so far very impressed!
    I've done a little reading over the last few months & liked the composition of Mitch Cotters old B1 plinth/base that worked very well with the SP10 & DP-6000. Cotter used aluminium & some sort of plastic 'sandwich' & my thoughts were to try an aluminium/acrylic top plinth for it's rigidity, weight & damping through the 2 different materials.
    I bought the VPI as a start point my thinking being, I could use the VPI lower plinth & spring suspension/Isolation with aluminium/acrylic or slate top plinth maybe!?
    A guy over on the Wam pointed out a new site that a guy called 'cat squirrel' had put together after alot of research & measurements into damping factors & this proves to be very interesting! Cat Squirrel uses Ider drives (lenco IIRC) so damping is probably more important because of rumble, but there's still advantages to be gained for DD or even the belt drives by using a plinth material with a better damping factor! I will link the site for anyone wanting further reading, but it seems a couple of materials came out on top, them being "Newplast" & a reconstructed wood called "Panzerholz". Most of the often used materials don't come out so well i.e. ply-wood, Mdf, Slate, metals etc.
    In recent past mass seems to of been what we've looked for in multi-layer ply-wood & slate type plinths. This research into damping factors says that the plinth thickness & WxD measurements are directly related & for a size of plinth will have an optimum thickness! It's very interesting reading indeed!
    Jonjin who pointed out this site has gone on to build a "Panzerholz" plinth for his SP10 (well I think Russ Collinson did the cutting as Panzerholz is very hard in fact bullit proof) The results he's getting sound very very good indeed! An improvement may-be over the tombstone slate plinths it seems (not that JJ's A-B tested them)! So I think my next port of call will be to order some "Panzerholz" & see how it compares to my steel/fibrous sandwich!
    Here's "cat squirrels sites & research...
    http://qualia.webs.com/plinths.htm
    http://qualia.webs.com/dampingfactorvalues.htm
    And here's Jonjin's thread about his SP10 plinth over on the Wam
    http://www.hifiwigwam.com/showthread...plinth-project
    Some very interesting reading anyway & does seem to bare out with JJ's plinth project!
    Cheers, alfie.
    alfie
    Main System: Denon DP-6000 VPI Base/Fidelity Research FR64s/Ortofon SPU Royal GM MKII/Shelter 901/Auditorium 23 SUT/Pure Sound P10/SB Touch or Audio Note CDT & M2Tech Young Dac/BL Audio LP-1/New Audio Frontiers KT66 Legend/Living Voice OBX.
    2nd System: PC/Foobar/E-MU 0404 pci (Modded)/AVI ADM9/Rel Strata II subs.
    Acetal (Delrin) is the material to go for IMHO, I am getting one made for my Techie when I get chance to to an autocad drawing for it! That with the Oyaide mat on top for mass and the weight will be a product to die for, opinions differ of course!
    Quote Originally Posted by Mains Cables R Us View Post
    Acetal (Delrin) is the material to go for IMHO, .............. opinions differ of course!
    What brings you to this conclusion Dave?
    I'm all for listening to a product & judging it's merits that way!
    But I'm finding this 'Damping factor' research quite interesting, adding a little science to plinth building!
    Acetal used alone is someway behind alot of materials from damping factor point of view, if all cat squirrels measurements are to be believed!
    alfie
